macro solid edge to open 3d and 2d and create file step and dwg or pdf
  • Thread starter Thread starter WAR85
WAR85
Good evening,
I would need to create a macro that automatically gives a folder open in solid edge all 3d files contained in it and save them in step format and also all 2d files and save them in dwg or pdf format.
Can anyone help me? . .
thanks in advance for availability.
ciao,
qui find an excellent starting base on which to easily add the desired operations for each file type
a previous version can also be found in the solid edge installation folder on the custom\batch\bin\batch.exe path
if you have to insert customizations you want from the first you tell
Good day,
I thank you for the answers, I apologize for my ignorance in the field of programming in visual basic, but I don't know how to change the executable file of the macro.
Good day,
in this case you can use batch.exe that you already find in the folder I indicated in the previous post
Hello, thank you for letting me discover this great function! !
How does it work if I have the teamcenter archive? How would you do that?
I am sorry but I never had to deal with teamcenter; does he have a similar function?
alternatively you should extract local files to export and then use the usual batch.exe
