merge points clouds with autocad
  • Thread starter Thread starter mokarta730
mokarta730
hi to the whole forum, my name is antonio is very few that I quit with autocad 2007 I have proposed a job that is to unite the clouds of points.... .
Simply add scans made with laserscannerd 3d....
Here I was looking for some guide or manual for this topic... .
Can you help me? ? ?
I do not think that autocad has such features that is typical of reverse software such as geomagic, rapidform or polyworks.
Look if it can help you. ..but it works on acad 2011. works until August 2011. Maybe it will be implemented in the next releases.
http://labs.autodesk.com/utilities/shape_extraction_autocad/
the link I gave you? ? ?
It's really Tristan who gave it to you...
without obligation, zipper and attach here the .dwg containing points: Let's take a look at him and we can tell you if and how to fix the busillis.
true, autocad was not meant to handle millions of points, but reading this phrase:
"autocad 2011 now contains a native point cloud engine which is powerful enough to handle up to 2 billion points of scan data."
I think that innovmetric &co. They're not sleeping peacefully. . .
Your emailswhen you have generated i.i.n . from the cloud of points, could you post it here so that we get an idea of the power of the plug-in signaled by tristan?
files are .dwg and are practically factory scans made with laserscan3d
I'm sorry, but maybe I don't understand.
if you need to merge points clouds and are dwg files then open one and insert the others with source 0.0.0 (if they are all clouds acquired with the same origin).
If you need to reconstruct a 3d model from the clouds then you need to use a specific sw or at least the already reported plug-ins.
