messe in tavola solidworks 2014
clark85
use solidworks 2014, I have to make some axiemi boards.
1 - I would like to have the effect of the attached photo (it's a little small so!!!)
In practice, I would need to "lead" some components (and its lines) and keep "transparent" the other components that I do not care about.
Is it possible?
sincerely I do not even know if the attached design is made with soloworks or with other software but the effect I am very interested in.
2 - Can you color the lines of some components?? to highlight this component?
thanks to all of the help!! !
Is it possible?
Bye!
both things are feasible.
select line->color line can be a solution to highlight only some lines. uses the levels and the line format. tools explained in the help
(I think there's a solution to color all the lines of the part but I don't think I'm flying without sw).
to hide details in the feature manager open the curtain of the sheet and the axieme, look for the detail you want to hide->click with the dx and hide/show component or directly in the view button dx on the component to hide->show/hide component
the image is actually too small...it is more an icon than an image . :-)
1) by right-clicking on the view and then going on the view properties you can decide to show hidden bodies.
2)clicking the right button from the view tree that interests you on the component that interests you can define the character of the line (thickness, hold. . . )
3)If you define layers with different colors, you can associate the color layer component for each view.
I hope I made myself understand. . .
If you can't, I'll get you some pictures.
Okay, thank you.
the fact of hiding the components I knew him,
the being able to change the character of the line is comfortable but precisely allows only to be able to change the thickness and type but not the color.
so maybe the solution that does to my case is to create some special layers to put the color that interests me.. .
now the question is:
how do I create various levels? ? ? ?
