mil-std-810g method 506.5
Mau37
I don't know if this is the right section for my problem. work for a company producing military shelters. we need to get the certification mil-std-810g method 506.5. This method is used to evaluate materials that can be exposed to rain, water splashes or water dripping during storage, transit or operation. I attach the pdf file for more information.
I would like to know if someone knows companies that produce this type of machine, to perform this type of test.
Thank you all!
hi, I think I understand that your goal is to produce a shelter that meets those standards and that it is certified not to build an equipment to perform that kind of tests, equipment that then should be certified. If that's how you have to find who does and certifies these tests.
Yes, our company must certify its shelters by submitting them to this test. I don't know if it's possible to build your own test equipment and then make it certify to make the test legally valid. In this case we would build it internally. in any case any suggestion is appreciated, companies that perform and certify the test or companies that produce the equipment to sell it.
