shinjy01
Hi, I'm just using solid edge v20 and they're completely self-taught :biggrin:
I also tried with the "search" function but I did not find anything about it, perhaps it is xkè is a simple thing for you, but I do not come to head :biggrin:
the problem is this, I designed 2 rods with 2 holes you have lati and a sort of crank, on the crank I made a socket, I assembled the hole of the wand with the crank socket with a screw, everything moves manually rotating, I removed all the constraints and turns the screw in its seat, only that I can not make it move inside the asola
you can explain to me step by step how you do (doing nothing for granted:biggrin: ) Since they are in the first weapons? ?
I also attach the file, so you can find where the error is!
I want to move the handle for the length of the 2 sunbeds.
thank you very much anticipate to those who will help me!!!
elvis
elvis
