janlo1986
hello to all, I present myself as a mechanical engineering student of the bari polytechnic, I must support an examination in which the use of featurecam is required. my project of year is a piece that requires milling both on the upper and lower side then after a processing the crude must be turned and reassembled on the countertop board. I created two setups one for each face, and on each setup the related processing. when I run the 3d simulation everything goes well but as soon as I start the simulation machine, something strange happens: the work is good if done separately (only if there is a check on one of the two setups), if I start the overall simulation, positioning is all high
Can you give me a hand ?, what's wrong? thanks, hello
ps I attach a simple example of a parallelepiped so it is easier to understand where I am wrong, thanks again
