new version parasolid v27.1
News
the version of parasalide v27.1 proposes numerous improvements to support efficiency and effectiveness in workflows on complex modeling.
these improvements allow developers to realize new applications to provide a step change in the productivity of end users.
parasolid provides a very high level of geometric functionality that can be decidedly more productive and robust, made at the kernel level, which allows developers to realize new applications and focus on other needs of their customers.
advanced areas of parasolid v27.1 include mixing, surface , modeling support, platform support.
These improvements are in addition to numerous improvements to specific sectors and workflows.Blending blendingv27.1 parasolid is able to ensure extensive control over the shape of mixtures.
This extended control allows end users to obtain the exact form that is required for functional or aesthetic purposes, illustrates the use of blending as a complex modeling technique beyond their historical role with simply roundings at the edge of the model.
improvements allow:
• more easily control the g2 face blending profile, providing constant depth and inclination values
• you can define the blending parameters to change the edges of the model, change the edges and ensure a smoother result.
surfacingParasolid v27.1 improvements are able to give more flexibility to achieve desired design results within an operation, which eliminates multiple operations.
surface improvements allow:
• replace square edges created by a sweep on a long profile, a long path not g1, with rounded corners
• align the parameterization of extruded surfaces with the extrusion direction
• optimize the parameterization of the new face when replacing a series of faces with a single face
• sweep a long profile, a path that extends beyond one or more faces used to block the profile
• sweep, a solid tool to realize a very long path and specify that a single face or a set of faces of the instrument are not important for the result and that the sweep should be replaced by a simple capping surface.Parasolid-27.1-.webp
modeling supportv27.1 parasolid includes changes to existing features to assist detailed modeling in a few steps.
v27.1 parasolid modeling support improvements allow:
* print a series of curves that match a face, like a group, which improves performance and robustness
* print a curve on faces of a body with greater influence by controlling how to print on hidden facesplatformin response to customer requests, parasolid v27.1 and bodyshop v27.1 for microsoft windows are now compatible with the microsoft security development lifecycle, which is a set of standards aimed at reducing the incidence of security vulnerabilities in the software. It is a precaution to improve the protection of the platform as there are no security vulnerabilities reports in these libraries.
