non trovo collegamento ansys in solidworks
Adrift
hi, on my pc I installed solidworks2015 and ansys 16.2. on the various network tutorials I saw that to import a solidworks object into ansys just click on the link of solidworks, which should automatically appear if the two software are installed on the same computer, but on my there is no: when I click on "add" a list appears but there is no ansys. Could it be because of the installed versions?
credo tu debba avea solidworks simulation premiumhttp://help.solidworks.com/2013/ital...347e1eef68e757
then in this case how do I charge in ansys a solidworks object?
Are the two software regularly fired?
solidworks yes, ansys I am not sure: at first when I opened the workbench gave me an error of the type "no servers provided", then I managed to fix it, following the guide to the installation of the license. I'm not sure it's all right though, because in the anslic_admin client utility, if I click "display license status" says: error getting status: no server lines in licensed files. (-13.66)
In this case what? It's not an alternative.
If you have simulation express you can't do it. is included in standard and professional solidworks packages
if you have premium simulation you can do it. is an additional update that you pay aside
So which one do you have?
What I wanted to say is that even if I can't let the two software interact directly, there will be a way to use an object created in solidworks in ansys, right? I read around that you have to save the object in some specific format but I didn't understand much. .
I have solidworks student edition
