offset in xrif and c# blocks
PlannerRoad
offsetinxref
the autodesk has published in its autodesk labs a plugin to use the offset command with external references.
This plugin, written in c#, was tested on autocad 2007.
in the compressed download file also the sources of the utility.
here you can find the plugin:
http://labs.autodesk.com/utilities/offset_in_xref/read also here:
http://labs.blogs.com/its_alive_in_the_lab/2009/09/our-first-plugin-of-the-month.htmland in particular the article of the author of offsetinxref:
http://through-the-interface.typepa...n-of-the-month-now-live-on-autodesk-labs.html
