overprinting, series productions in a few days
thanks to the use of aluminum molds, thermoplastic materials and liquid silicone rubber, proto labs is able to guarantee at a competitive cost, both the production of prototypes, and the production of series from 25 to 10,000 and more pieces (PHP 3, PHP 4)In less than 15 days.
[TABLE="width: 630"]
<tbody></tbody>[TR][TD][TABLE="width: 240"]
[/TD][/TR]
[/TABLE][/TD][TD]it is very simple to get overprinted pieces in short time: Just provide i 3 file cad 3d (1 file of the substrate model, the model of the overmolded part and the final component); proto labs designers will develop mold models taking into account partition lines, material injection points and extraction points. so you will get the models necessary to the production of the component in all its complexity that, once approved by the customer, will be sent in the form of cnc paths to workshop machine tools for mold production.[/TD][/TR]
[/TABLE]production of the mould that takes place within the proto labs itself: the numerical control machines brake the aluminum piece, so as to obtain the shape of the desired molds.
an operator intervenes on the surface of the moulds depending on the type and degree of finishing required by the customer; exceeded testing, the equipment is ready for production in series: is injected into the mold the material that composes the substrate and subsequently, is injected the second material in order to obtain the coupled component, exactly as from project and in very reduced times.
