parameterization via formula
Hubble
Hello, excuse me if I still take advantage of this forum.
I'm making a flanged hub in top-down mode. I was asked to use the formula command so that all measurements are parameterized according to the diameter of the shaft. I parameterized the length of the shaft and its housings for keystrokes and it's okay. I then realized the hub and I parameterized with the command formulates its sizes compared to the diameter of the tree. In this case, however, if I try to change the diameter of the shaft, the size of the hub does not adjust accordingly. What can I have done wrong?
thanks in advance
I believe the selection in the formula, (if you miss the syntax of the command, it immediately generates error)
I usually
create geometry
I put the constraints
select the constraint, right click, formula, open the window, place me on the empty field, click on the constraint to be used that appears already ready with the syntax in the field and add the operands (e.g. /2 )
I usually
create geometry
Thanks again, I try again and let you know
I usually
create geometry
I continue to have problems with parameterization : Cattura.webpI parameterized all the size of the hub in this way and I don't understand what's wrong
Isn't it missing the update? not having the update set automatically, does the system not update the value?
quy hoạch hạ tầng lã* má»™t trong những ná»￾n tảng quan trá»￾ng trong việc thu hãºt dã¢n cæ°, vốn ä‘ầu tæ° vã* thãºc ä‘ẩy sá»± phã¡t triển. riãªng tại tp.hcm trong những näƒm vừa qua luã´n cã³ tốc ä‘á»™ triển khai hạ tầng nhanh vã* tạo ra những ä‘á»™t phã¡ vã* sức hãºt mạnh mẽ, trong ä‘ã³ khu vá»±c phã*a ä￾ã´ng vã* ä￾ã´ng bắc thã*nh phố vẫn tiếp tục lã* tã¢m ä‘iểm.
khan hiẾm quỸ ä￾Ất cáº*nh sã”ng
tại tp.hcm, quỹ ä‘ất ven sã´ng ä‘æ°á»£c xem lã* “ä‘ất vã*ngâ€￾ vã* trá»ÿ cã*ng trá»ÿ nãªn khan hiếm khi chỉ cã³ khoảng 80km mặt tiá»￾n sã´ng nhæ°ng tã*nh ä‘ến thá»￾i ä‘iểm hiện tại, những vã¹ng ä‘ất nã*y ä‘㣠ä‘æ°á»£c phủ kã*n bá»ÿi loạt dá»± ã¡n phã¢n khãºc bất ä‘á»™ng cao cấp. chỉ tã*nh riãªng dá»￾c bá»￾ kãªnh bến nghã©, tã*u hủ, hoã*ng sa, træ°á»￾ng sa ä‘㣠cã³ ä‘ến khã´ng dæ°á»›i 20 dá»± ã¡n, ä‘ặc biệt lã* khu vá»±c dá»￾c sã´ng sã*i gã²n lã* næ¡i cã³ nhiá»￾u dá»± ã¡n cao cấp vã* giã¡ bã¡n khã´ng dã*nh cho số ä‘ã´ng, tuy nhiãªn tất cả ä‘á»￾u ä‘æ°á»£c khã¡ch hã*ng säƒn ä‘ã³n vã* luã´n trong tã¬nh trạng cung khã´ng ä‘ủ cầu.
ä￾ã” thỚ sinh thã￾i bãšn sã”ng sã€i gã’n
chã*nh v㬠lẽ ä‘ã³, bảng giã¡ saigon riverside city vá»›i vị thế vã*ng mặt tiá»￾n sã´ng sã*i gã²n vã* kết nối ä‘ại lá»™ phạm väƒn ä￾ồng, ä‘æ°á»£c xem lã* má»™t trong những dá»± ã¡n khã¡ hiếm hoi trong bối cảnh những quỹ ä‘ất trung tã¢m vã* cạnh sã´ng sã*i gã²n ngã*y cã*ng khan hiếm. dá»± ã¡n saigon riverside city thủ ä￾ức hæ°á»ÿng trá»￾n lợi thế mặt tiá»￾n sã´ng sã*i gã²n, mang phong cã¡ch thiết kế của má»™t resort sinh thã¡i ven sã´ng vá»›i gần 100% cäƒn há»™ ä‘á»￾u cã³ hæ°á»›ng nhã¬n ä‘ẹp vá»￾ sã´ng sã*i gã²n, hồ sinh thã¡i vã* hệ thống cã´ng viãªn bãªn trong dá»± ã¡n, tất cả sẽ mang ä‘ến cho cæ° dã¢n những giã¡ trị sống hoã*n mỹ vã* riãªng biệt.
kã¨m theo ä‘ã³ lã* má»™t thế giá»›i tiện ã*ch thu nhá»￾, ä‘æ°á»£c quy hoạch hoã*n chỉnh vã* khã©p kã*n ngay bãªn trong dá»± ã¡n vá»›i 6 phã¢n khu, 36 tiện ã*ch chuẩn resort cao cấp nhæ°: bến du thuyá»￾n, ä‘æ°á»￾ng tản bá»™ vã* cã´ng viãªn cạnh bá»￾ sã´ng, quảng træ°á»￾ng trung tã¢m, phố ã¡nh sã¡ng, phố mua sắm, hồ bæ¡i, khu thể thao trong nhã* vã* ngoã*i trá»￾i, væ°á»￾n bbq, hồ sinh thã¡i, væ°á»￾n treo… ä￾ồng thá»￾i bãªn trong dá»± ã¡n cã²n cã³ trung tã¢m thæ°æ¡ng mại 04 tầng táº*p trung hæ¡n 15.000m2 trong tổng số hæ¡n 24.000m2 sã*n thæ°á»£ng mại của toã*n dá»± ã¡n, ä‘ã¡p ứng tất cả nhu cầu mua sắm, giải trã*, äƒn uống, chäƒm sã³c sức khá»￾e… khã´ng chỉ cho cæ° dã¢n bãªn trong dá»± ã¡n mã* cã²n lã* ä‘iểm ä‘ến cho cæ° dã¢n trong khu vá»±c.
ngay khu vá»°c phã￾t triỂn máº*nh mẼ cỦa háº* tẦng khu ä￾ã”ng
saigon riverside city thủ ä￾ức sá»ÿ hữu ba giã¡ trị vã*ng “nhất cáº*n thị, nhị cáº*n giang, tam cáº*n lá»™â€￾, cã¹ng vá»›i hã*ng loạt những tiện nghi, dịch vụ hoã*n chỉnh, khã©p kã*n, vá»›i giã¡ bã¡n dá»± kiến chỉ từ 1,28 tá»· ä‘ồng/cäƒn há»™ 2 phã²ng ngủ, ná»™i thất hoã*n thiện, saigon riverside city ä‘æ°á»£c xem lã* khu cäƒn há»™ hoã*n mỹ, ä‘ã¡p ứng trá»￾n vẹn nhu cầu an cæ°, ä‘ầu tæ° cho tất cả cæ° dã¢n thã*nh phố.
