press issues with draftsight
rup84
is the first time I write on a forum and I ask you a little patience.. .
I've been using draftsight for a few weeks, the free version.
I have windows 8 and then I installed the 64-bit version.
Everything works well enough, but the main problem is that it does not print.
does not print pdf and does not print even from the printer.
Can anyone help me?? Am I the only one with this problem?
Thank you!
for pdf I recommend the use of pdfcreator that works as a virtual printer.
I don't know about the printer. Which printer do you use?
if you do not solve there are other free cads such as nanocad and doublecad xt that you can use even only for printing.
