press release: shark fx cad 3d parametric
  • Thread starter Thread starter mind@ware
mind@ware
complete design solutionshark fx is a complete 2d/3d solution for digital design that allows easy modeling, photorealistic rendering, animation and precise design all integrated into one software. shark fx is the complete solution to develop the concept through digital prototyping.
Usoshark fx is the simplest and most powerful modeler designed for designers or for those who need to model complex shapes with extreme speed and ease. designed to be intuitive and precise, has a wide set of 2d and 3d tools.
intelligent designall modeling operations are stored in a building history. each operation remains active with all its parameters. changing a parameter or changing a reference, all related modeling automatically updates.
Moreover the use of two-dimensional geometric constraints allows to change the profiles that have generated an extrusion or a revolution in 3d, without requiring the designer to erase and regenerate the entire model.
new membership fees, when changing the model, are automatically updated in the executive boards.
Versatile modeling methods shark fx supports an integrated collection of 2d, 3d modeling tools, surfaces and solids. has typical 2d controls and related modifications, 17 surface construction methods, blending, 3d fittings and bevels, shelling, stretching, twisting, bending, and a large library of solid modification tools. all surface and solid modeling automatically has the construction history that allows the quick modification of the created objects, without necessarily starting all from scratch
rendering and animationshark is rich in rendering and animation tools, useful to communicate and sell your ideas. drag & drop materials, decals, backgrounds and preset settings to transform your ideas into effective photorealistic images. allows you to create jpeg, bmp, or high resolution eps files and large size, or create quicktime vr or flight movies through models.
drawing and annotationwith shark fx the executive boards are automatically generated with a mouse click! using the command of the table. carefully quoted and adding details, sections, or auxiliary views your designs will be complete in a few moments
share data with mcad and enterprise solutions
Unlike polygon-based software, shark fx uses a precise and powerful kernel that facilitates data sharing using iges, step, autocad dxf/dwg and sat formats.
shark fx also supports import into native format of catia v4 and pro/e wildfire.
www.sharkfx.it
Hello I am new to the world of shark fx, I wanted to know tips about this software! I saw you know him!
Thank you very much
He sells it, we also miss him not knowing it.. .
I tried it and compared to cad as swx, if, inv is to say little farraginous in addition to missing all the functions of assembly of the parametric cads, then forget the simulation of cinematisms etc.
is a revisitation of vellum, which was a revisitation of I don't remember which other cad per mac.
Hey, thank you, Marco, so let's just say it sucks?
in meadows what can you get out of good?? Can you do the cam route?
What I recommend at the same price
Thank you very much for your precious advice!
:biggrin:
Before I say it sucks, I'd say it's better to try it. I use it daily and for me it is a fantastic program! for the price it has, it is the only software that allows you to work with solids and surfaces, switch from solids to surfaces and polygons and vice versa, it is a real cad (which is difficult to find in other common modelers), then it has the 2d constraints that allow us to make parameters 2d or create mathematical relationships between them, then it has lightworks as renderser (compreso hdri and radiosity), then it has the mass you can model the 3d object using modeling tools and then you can intervene on one of those commands by changing the parameters without having to remodel everything from scratch!
then has an avalanche of import and export formats (for example in export writes 3ds, dwg (ver. 2010), acis (vers. 20), step, iges, stl and to say also illustrator and eps!
it is enough for a product that costs only 1795€ in the + expensive version.
not all I want to spend 6000€ or more then use 5 or 10% of the tools present in the various swx, if, inv. only the module to export to illustrator for these software costs perhaps as a shark license.
I forgot
...... before you say it sucks maybe go see the tutorials on www.sharkfx.itThe rendering gallery is not bad too!
Of course no one feels offended
