daxo
in the company where we work catia v5r21 to plan 5ax working centers with direct drive board to return.
to set the mixed turning / milling processes imposed as machine cn - back to sled miltipla.
I have always found a malfunction that often compels me to subdivide machining in separate working groups.
I'll explain.
normally for practicality I divide the working cycle into phase (working group called phase. . )
the various phase sleep composte of n - processing programs which contain various working strategies both turning or milling.
for post processor problems never mix turning or milling in one single processing programme.
so according to the details to be realized I will have a phase composed of several processing programs.
when tax eats cn machine - multiple sleigh lathe the definition of the fifteenth working programme, in the same phase, is an unpleasant anomaly. practically the order of my processing programs is mixed randomly.
if I were to follow the order that Cat proposed would be a catastrophe:3559:.
in the case of definition macchina cn - any other option provided (fr3 axes - 5 axes cutter - vertical lathe. . . .) the anomaly does not appear (ho phase consisting of more than 100 processing programs without experiencing any problem)
Is that what happens to someone?
if you si. He managed to understand why and how to overcome the problem.
waiting for a vs reply early thank you and greet all
bye :36_1_11: daxo
I'll explain.
bye :36_1_11: daxo
