processing render on pc remotely
dalmott
I should perform the render of a car, but my pc does not make it (or more than anything, in long times)
I would like to be able to exploit all the power of a pc we already use to make calculations; is it possible to redirect rendering processing?
Thank you very much
I don't think you can only use the cpu of a remote pc, I'm afraid you'll have to use your + remote.
test in tools/options/photo studio/satellites and there declare the names of the (up to 4) remote machines you want to exploit.
Alternatively, install a caia on the remote machine and then leave the calculation task to that.
ps: I often leave the rendering calculations all night and the result I find it the morning after.
ps2: I can't wait for the v6 to arrive with the new cat's rendering.
Thank you very much.
I was wrong looking in the guide! ! !
Your concern is right, I have to let my pc calculate as well.
It seems to me that it depends on the type of network between the various pcs, I connected it to one with 32 units of calculation, but the improvement was not so obvious, perhaps it is also fault of the xp.
I'll have to try a seven.
Thank you very much
