moro76
Hi, I wanted to understand if in solid edge that I recently used there is the possibility to use the equivalent command to the "cut edge project" of inventor.
First you have to explain what that command does. Even better if you tell us what to do.Hi, I wanted to understand if in solid edge that I recently used there is the possibility to use the equivalent command to the "cut edge project" of inventor.
