property recall in the carts
  • Thread starter Thread starter libero85
libero85
I have a problem, the recall properties type file name, author and company work,precisely: file name from file name with or without extension, author and company from file properties.
while the recall properties connected with the particular in 3d material type and mass despite I gave a material to the piece does not give me....
help me:confused:
It has to work.
How does the variable name appear? ? ? ?
you must report the same form of the properties name, etc.
Why not use the link editor inside the call?
so you don't have to be out there to find the property names.
is the button at the bottom left of the dialog
but I use that....and that doesn't work...and I don't know why....while with the connection to the mass that gave me gerod works
but if I want to decrease decimals like just a number after the comma?how do I do?
you must write the formual so:
%{massa/@1|r1}
where the /@1 stands for a decimal after the comma, if you put 2 you will have 2 and so on... if you put 0 (zero) you will have rounded it without decimals.
