radio
I have a doubt about the correct symbolism to use to quote the soldering you see in the annex.
normal use of a combination of graphic symbols such as the one you see in the upper part in the figure, this combination is expressly mentioned in the aws while in the uni en 22553 no, in paragr. 4.2 and 4.3 we talk about possibility of combination of graphic signs and additional graphic signs, but it is not treated the case in question.
As far as I am concerned, I will continue to use the upper symbolism, which seems sufficiently intuitive to me; the cad that I use now also gives me the possibility to concatenate symbols as you see below in the annex, what do you prefer or what do you think is more correct?
