spriculizzu
Hi guys, I'm antonio and mechanical engineering firm. I should make a simulation of a radial turbine using fluent. I designed the desired, the impeller and the diffuser and I made the mesh. Unfortunately, however, when I open fluent, imposing an input pressure and an exit, there is nothing the air flow through the turbine. If someone had faced such a problem, I'd like to have advice. Thank you.
