archilan
Hello, everyone.
I have a problem with the spline: I vectorized some raster designs and managed to have contours. the program I use generates 3d polylines, but using the contour command I can redesign them as 2d polylines. the problem is that the contour of these drawings, coming from images to medium resolution, are generated very serrated. to try to reduce the sawings I transformed the polylines in spline and became wavy but still give an uncertain contour. I would like to drastically reduce the spline points. Is there a command that does it automatically by giving some settings? I remember that in think design there is a command that is called "approxious curve" (or something like that) that allowed to reduce points and bows of a spline. with autocad you can do without deleting point by point?
Thank you very much
to the
Thank you very much
to the
