retained annotation : association quota nx
FiloST5
Good morning to all,
we use nx 10 with teamcenter. model cad 3d and board associated are arranged under the same item revision. it happens that by necessity it is necessary to duplicate the part number to create a new code ( starting from the current).
Following this operation, the new item revision and associated datasets are generated correctly with new codes. when, however, I open the 2d (specification file ) that points to the associated 3d all the odds have lost the association..... then it is necessary to reassociate them one by one manually..... with considerable time spent.... :
Have any of you users ever encountered this problem? and can avoid such behavior? Could it be a wrong set of nx or teamcenter?
waiting for your kind help, thank you in advance.
thread
the behavior that signals is to say little abnormal, use tc with nx from a life and never happened to me. can you post screenshots (tc and nx interface) of what you step by step?
