revit vs edificius
Revit vs edificius... qual è il migliore?
  • Total voters
    7
Francesca1984
Hello everyone, I'm going to learn one of the two software, but I still have no clear ideas... I have seen demonstrations and buildingsus seems much more intuitive and with a rendering/animation compartment, much more performing, but of the other functions, I just don't know anything... someone who knows more or less about the characteristics, can tell me which one is better and why?
thanks to all:)
hi, at first I had your same need, since I mainly deal with photo insertions, I had seen in a demonstration the simplicity with which they were made with buildingsus and indeed I can confirm your impressions.
the program is very intuitive compared to other software that I tried especially in my case to make photo insertions with revit I had to use several programs and took away a lot of time, so I decided for constructus and except some defects I am excited about it, since they added the real time rendering module I also dedicate myself to the realization of presentations (mounted with external programs) but with more than satisfactory results considering that the whole project I realize it completely in buildingsus.
strengths: of course the photo insertion, ease of use, graphic rendering, texture library and online objects, integration with sketchups, frequent updates and fast assistance.
weak points: it does not have so many types of objects (I pay with sketchup!!), difficulty managing huge projects (but I will pass to the 64-bit version, hoping that better!!) and requires a graphics card quite powerful.
Ultimately I can consider myself satisfied! ! !
Since you're not hadid or plan maybe you better ask yourself another question, that is: "Who do I have to cooperate with in the future? What solution did he adopt? How much is there between the designers with whom I will have to interface? "
after which the answer can be one and one; download trials and try them and see which gives you a better impression
I go uphill.... who voted and expressed the judgement has used both programs for work i.e. he has realized a whole project with everything that goes behind (modifications added over the years....) or he has done only simple tests without any "committee obligation"..... .... . . . . . . . . . . . . . . . . . . . . .
