rigid towing bar for heavy trucks
  • Thread starter Thread starter odisseo 18
odisseo 18
Hello, excuse me if I intrufolo, if it were possible I would like to know if some experienced user could help me to dimensional in his parts a tow bar for recovery heavy means in the avary. we had to be hooked back to the towing bell that is used to hook the trailer rudder, and before a smaller bell or a hooking system. You could tell me how to fuck the various parts. a last question you would know to tell me if before some designer or engineer has made a safe service hook, as they are very often made of cast iron and when the vehicles strive during shooting or pushing or in curves they break causing damage to the cross and the motor with the risk of nailing in the engine compartment thanks to the attention http: / / www.sfiavenna.it / admin / archivo / offerte / 43 / barra% 20traino.jpg
Kit-Carrelli-19.webpKit-Carrelli-21.webp23185-72c51-barra-da-traino-professionale-per-camion-tele.webp
definitely must follow the product regulations. could partially follow eurocode 3 for a first sizing.
I would propose a fem and a static and dynamic study to fatigue.
thanks to your intervention, take into account that it should draw as maximum weight a 4 axes, the length of the bar should be around 2.5 meters to 3 m, the most critical points are the coupling bells, are subject to compression and bending traction in the curve , for action of the spring throw and push in phase of towing and braking of the vehicles ( pull/push), saipogan on the market there is a bell with safety system, many times before
I have no idea if there are safety bells because it's not my industry. However, you could cover the tow bar in open.
thanks for your precious time, I looked on the net I found this for the regulations:
with regard to structural resistance, the standard dictates the need to define the capacity of the hook according to the horizontal load (d) and the vertical static load (s) supported. the first is expressed according to the technical masses driving and towed (mt and mr respectively) according to the formula below, while the second is directly expressed in “dan
d=g xm x mr/mt + mr
the tests, are conducted, applying a f force that has a horizontal component (fh) a force proportional to d depending on the type of stress (progressive or alternating) and as a vertical component (fv) once and a half the vertical static load
the norm cuna nc 338-02 defines real categories of hooks, referring to applications of typically Italian towing systems. for each of these categories, dimensions and capacity are defined, while on homologation tests are required with static load applications, also recognised at Community level. depending on the product in development, it is possible to perform structural numerical analysis also for such tests obtaining results and information such as those mentioned for fatigue tests
1. the semotive operating machine must be set up with type hook approved according to the tables or approved in accordance with Community rules established for semotive agricultural machinery or for motor vehicles.
2. The hauled operator must be set up with type-approvals approved according to the sewage tables or approved in accordance with Community rules established for agricultural machinery or for trailers.
2.1 In the event of a set-up with a tow-eye corresponding to the cuna nc 438-06 table, it can be driven by semovent machines or by agricultural tractors towed with tow hooks corresponding to the cuna nc 338-02 table.
2.2 in the case of equipment with attack devices in accordance with Directive 94/20/ce or with the tables provided for in Article 438-40 and in Article 438-55, it can be driven by vehicles for the carriage or by machines operating on the road, equipped with attack devices in accordance with Directive 94/20/ce or with the tables provided for in Article 138-55.
art. 3.
towable mass of semovent machines
1. the maximum value of the trailerable mass identified as the difference between the maximum mass at full load of the complex, consisting of the semotive operating machine and the machine operator towed, and the maximum mass at full load of the semotive operating machine: This value is subject to compliance with the tow ratio referred to in Article 1, which cannot exceed the value of:
(a) 1 for rubberized wheel-driven machines, for non-moulded wheel-operating machines or for those with a brake-free machine;
(b) 2 for rubberized-wheel-drive-driven machines, for non-moulded wheel-operating machines or for those clinging machines, whatever the type of braking of the complex;
technical parameters of towing systems
value d: it is defined as the theoretical reference load for the determination of the dynamic horizontal theoretical force that the driving vehicle and the trailer exchange; dc value: it is defined as the theoretical reference load for determining the dynamic horizontal theoretical force that the driving vehicle and the central axis trailer exchange; v value: is defined as the theoretical reference load for the determination of the dynamic vertical theoretical force that the driving vehicle and the central axis trailer with mass greater than 3.5 ton exchange; s value: it is the static vertical load that the central axis trailer transmits to the hook in static conditions; u value: it is the vertical load transmitted from the semi-trailer to the saddle.
- towing hooks and eyelets 1.1 - traditional trailers
in this case the characteristic technical parameter is as follows:
d = g xt x r/t + r
where: g = acceleration of gravity taking 9.81 m/s2; t= represents the maximum technically admissible mass, expressed in ton of the driving vehicle; r= represents the maximum technically admissible mass of the trailer expressed in ton.
c) 3 for rubberized wheel operating machines, if the mechanical type brake device;
d) 4 for rubberized wheel machines, if the braking device of the mixed and automatic type complex;
(c) 5 for rubberized wheel machines, if the braking device of the continuous and automatic type complex.
