_mattia_
hello to all...my problem definitely for many of you will be a banality. .
use inv2010. together I have 2 trees and I want to create a roller chain to transmit motion between these two. by design there is precisely the option roller chains but I can't understand what options to assign to 2 crowns(pos. free slide, fixed by existing geometry, rotating controlled slide etc.) so that it can then make an animation in which they spin correctly connected to the two trees... .
Thank you! !
Thank you! !
