Samples from solidedge
ASSAMEC
in solidedge in the table environment, working on the assembly sections, I saw among the properties of the view the possibility to derive from the style of the dashboard.
So I thought that by popping this option, the relative sampling was aligned to what set in the part environment for its part.
I did not find, however, in part environment, where to set the restraint.
I first thought it was related to the type of material, but it is not so and by the way it would not be useful because if I do the section of a assembly of parts all of the same material I would have a section all with the same deduction.
I thank in advance all those who can give me a hint
what you are looking for is in the material tab, should be little below the color setting.
the style of the dash is derived from the material, among other things there is a legislation to follow. in any case, the spacing of the lines of the dash is obtained according to the area of the section, the angle of the dash is alternated by 90° for each area.
it is then possible to manually intervene on each single deduction if it is necessary to make adjustments.
