Denis
I would have the need to save a color in the window of the visual aspect editor, where there are all the color thumbnails so much to understand.
then, after opening the window, we will click on + and rename the color, modify it and close the window.
the color remains in memory until the shutdown of proes.
I also tried, always from the visual aspect editor window to use save or save by name, but nothing.
It actually saves me a file in the directory where I was working but when I turned off, the color I created no longer see it together with other thumbnails.
But if I try to create another color with the same name, it tells me that it already exists.
So, how can I find the color created?
Thank you all.
Thank you all.
