scelta workstation per solidedge 2020/21
Jarno
Good morning to all, it's a bit that I don't show but I used the "search" :cool: before opening the thread.
I'm thinking of renewing the pc with the idea of then switching to the latest release of if (both stop at st5).
The Seller tells me:"For solid edge we recommend a workstation with w10 with these general characteristics:- cpu : from the st10 version uses multi-core in the table masses (faster tables) ...however prefer less cores (because they are not exploited by 3d) with more ghz (better xeon as workstations of even with memorycache)
- memory 32 gb
- reference graphics card nvidia professional picture p2000
- double disk of which 1 ssd in solid state where to install the cad.My hw dealer (hardware) proposes:i5-9500hard disk 1 ssd 256 gb m.2.
hard disk 2 ssd 1 tb
memory ram 32 gb
Windows 10 professional 64 bit operating system
graphics card:
svga pny nvidia picture p2200 pascal 5gbddr5 pcie16x 3.0 2560x1600 4x dp1.4 - 1x dp-->dv
svga pny pb nvidia quadro p620dvi pascal low profile 2gbddr5 pcie16x 3.0 2560x1600 4x mdp to dvi
Now I have tried to understand if xeon is to prefer to the i5 but to what little I have understood depends on which xeon but often the "i" are better
I just don't know about the graphics card.
the asses that we manage as a rule are not very large but often are with imported inside and with various pocci.. .
generally the cpu xeon have high performance on the multi core while the cpus of the serious "i" have high performance on the single core.
my advice is to take the cpu of the series "i" you find at the best price\performances. also pay attention to the generation of the cpu for example an i5 of 10th generation has performance higher than an i7 of 8th generation (at equal frequency).
if your asses as you say are not huge enough p620 can save you a few hundred € to invest in the cpu
I have a xenon cost a proposition and I don't think it's worth jumping from the i3 I had before
