script to remove raster image frames in multiple designs
zintonio
Hello.
I have 49 drawings in which there are references raster images to which I have to remove the frames. I wanted a hand to create a script that does this to me. I tried to sketch a script like:
_
_imageframe
0
_
_
but I can't figure out how to make it for the 49 tables.
thanks rpor66,
I had already looked at the createfilecript.xls in the past, but today I tried to use it negatively, in the sense that I chose the files then I put the commands and then pressed create scripts. created a script that doesn't work.
if I open the script with the note block is like:
_
_imageframe
0
_
_
repeated n times where n is the number of files I entered. does not hinder the path of the file. I wanted to ask why does not insert the paths.
