cromos
Hello everyone
I'm looking for sensors to fit into a device I'm planning
the sensor must be able to detect the presence of a pin of 10 mm diameter.
I was thinking about light emission sensors
that send a signal when the pin blocks the passage of light.
I would like to have some advice on the sensor type
the field of use:
temperatures ranging from -40 to 100 degrees centigrade
must be able to work even in rain conditions.
the minimum possible dimensions
duration of time
low energy consumption
power supply through photovolltaic energy.
economic
Could a solution result from the use of laser diodes that have 5 mm diameters?
Are there sensors with lower diameters?
Thank you for your cooperation.
the field of use:
duration of time
economic
