solids
is there in some way the possibility in the views dissected in a table to make only the lines of the outer edges of the objects/parts dissected more thick?
in the various options I found nothing about changing the thickness of the lines of the whole view, and the manual selection of each line to inspect it is too laborious.
I attach example. In practice I would like the only circumference of the circle to have a more often than others.
Thank you, hello!View attachment Parte1.PDF
