lorenzocalo
Good morning to all, I have to do a static mechanical analysis quite simple. a belt that flows on a semi-lindrical body and which is tracted on one side while on the other is framed.
I am having problems in meshare the "chighia" (often 3 mm) as at mesh performed, the procedure creates me very large elements that "come out of the belt"; everything ok instead regarding the mesh of the "body".
I directly attach the workbench project so that you can take a look.
