gerod
Here's my problem.
I installed win7 x64 on a macbook pro with bootcamp.
I can actually boot the laptop with win 7.
then I imported the same machine with a virtualizer (parallels) so that I can use win 7 with osx for some programs that run only on win7.
from virtual machine I installed se20, I launched the upgrade to 15 (there is to change the register).
had, if20 on the virtual machine leaves, on the native machine (part from boot with win 7) instead remains the boot window of if and from there it does not move.
I went to see what's wrong and she says:
I do not see the sp. 15 installed (version 20.0.0.96).
I tried with sfc.exe but nothing to do.
I tried to uninstall and reinstall trying to clean the log but nothing.
thanks, greetings
Do you have any idea what happened?a problem occurred that prevents the program from interacting with windows.
signature problem:
event name problem: apphangb1
application name: edge.exe
application version: 20.0.0.96
timestamp application: 46b3ab28
block signature: 2d0b
type of interruption: 0
version so: 6.1.7601.2.1.0.256.48
id local settings: 1040
signature additional block 1: 2d0bc724cbe7f2f6fb040c5e73a97a7c
signature additional block 2: 0024
signature additional block 3: 0024fa4347f670fd5a11ac9c6489f807
signature additional block 4: 2d0b
signature additional block 5: 2d0bc724cbe7f2f6fb040c5e73a97a7c
signature additional block 6: 0024
signature additional block 7: 0024fa4347f670fd5a11ac9c6489f807
thanks, greetings
