Sadsu
Hello everyone, it's not much that I use rhino and I'm going crazy in an attempt to figure out how to turn a polysuperfice into a solid.
I tried to take a look on the internet and on various forums, but I can't get over it.
Until the polysurface is closed, it might look like a solid, but I wonder if it really is. If I send the file in 3d printing what do I print? a solid inside or a polysurface and in the latter case with which thickness of the edge?
My problem is actually more complex. I have a polysuperfice and I want to split it up. But when I split it appears to me as an empty polysurface inside, I could also close it by extruding the base, but the doubt remains. What do I have? a solid or a polysurface?
I would also need to drill the polysurface that I would actually like to be a solid, but at the most I can pierce only the edges of the surface.
Is there a command to transform polysurface into solid?
thank you so much for the attention
