spirit tng
  • Thread starter Thread starter abosat
abosat
hello to all are user esprit since 2009 use 3-5 axle milling modules and I recently test the new tng platform.
Does anyone use it?
an exchange of views would be interesting.
Hello abosat,
I have anke in beta test the tng.
I would like to know if you find improvements like calculation timing and how to exploit your pc's resources?
I tried it a little bit, but I can't figure out how to exploit all the potential of the PC.
However great discussion.
hello to all, I started using it recently, count that I had visualmill to cam, I opened a world, I will let you know.
:wink:
Hello abosat,
for calculation times understood as processing cycles we are pressapoco as 2015 ... then it has to calculate the connections between cycles and if active raw automation and you have so many processing in the file then it becomes unmanageable and unstable (work with a core i7 and 16gb ram).
If we add postprocessor youth problems I must say that for now I am not very satisfied.
