vespa_83
I installed the upgrade with st7.
working with various old files that you exploit as much as possible if I have to create similar pieces, I find myself some problem with the new holes and material tables.
for the lossella fori, I was 7-8 years ago custom holes.txt adding some whitworth fillets and perhaps formatting gas fillets like "g 1 1/2". with st7 I have already copied and linked the table from programs to my server, but I did not make changes.
if I open a part with a hole "g 1 1/4" tells me that it does not recognize it, because in the file it is written "g1 1/4" that I sincerely do not like.
for the materials. with the pdm (edm) discharge the material property, then in the part, it was (and it still seems) automatic setting of the density, color of the part, hold for the sections in draft. the most obvious problem (I have not deepened) is that on many part the colors are written in English e.g. "steel" face style, the program writes to me "stainless steel" and the piece does not change color because the name indicated is not in the intended styles.
I would self-sustain a mass update of all the archived parts, also because there is no official procedure to realline styles and other, but it doesn't seem right to continue using obsolete styles.
how did you move for these two problems?
