sdc
Good evening to all,
I have a problem with a solid to which I extracted an internal shape, I explain better:
we take for example a tube made with a circle to which I subtract a circle of smaller diameter then extrude it and get a tube.
my problem is that when I try to copy the tube, autocad copies only the part formed by the outer circle and the result is that the copied tube becomes a cylinder. How can I copy the tube so that it remains such?
Obviously it is a more complex form of the tube.
Thank you all for your help.
