symbols surface roughness
emanuele grasso
I would need to write with catia the symbols of roughness as you see in the attachment.. I have searched but unfortunately there are several things that are not configurable to my liking for example the books (both those that close and those below, put horizontal) and also the number that you can only put on the root instead of above the triangle as you see in the photo.
there is the command "surface texture" but, in my opinion, it is not complete and not configurable
As for the number above the triangle instead of above the root I solved by the standards, the question of the notebooks would still remain
Can you track what you want and think doesn't work with v5?
What version do you use?
my version v5-6r2021
according to me the command that is unconfigurable is "surface texture" (the one under t). what I would like to do is to put symbols at the root base (type rows or quads)
If it is not a one configuration, they will never make it to you, if having quad brackets is just your request, or some particular customer will never be made............ the symbol does a lot of things but all in line with the specific one of the welding symbol........ Maybe I'm wrong, I use them little but I think it is.
after I try to see in the standards if there is something............ .
most companies use wording in paper, symbolic or numerical.
leave the indications in the middle of the drawing is obsolete.
methods are the traditional one with all the degrees and the simplified one that is going for the major (fig.23)Screenshot_20221224_153134.jpgIn fact in 2022 it is a little useless to have indicated all the degrees of roughness.
Unfortunately, the company historian on how to fill out the carts penalizes common sense and legislation, unless there are mental openings in favor of the practicality approved in the staff.
Sorry... I started in fourth place with the welding symbols, but you asked those of roughness... :
