LeanitRoberto
hi to everyone, I'm new to the forum, my name is roberto and I'm consulting for the streamlining of design and mechanical production.
I am making a project with a client who has a working department with nc machines, currently programmed by the keyboard of the machine, I found in the company a working mastercamx3 license, I believe purchased in 2008 and never used. as first step I want to use it to determine the processing times of new requests coming from the technical office, I have available the stp file of the finished and pdf design. Currently quotes are made in excel, I would like to make some experience and put in motion mastercam, then update the license and put it in production.
I have a couple of questions that are probably so basic topics that in the various tutorials I have seen on the internet are given perhaps for discount: I have to make trees with bearing mounting areas, pickers and sealing seals, they are usually more than 3 meters long details and therefore wrong the speed of advancement entails very wrong estimates of working times.
if I have to realize areas with roughness 1,6 or 3,2 how do I determine which progress to set? Is there any mastercam functionality that helps me (given the radius of the tool), or is it an information that I have to give to those who sell the tool plates?
regarding tolerances I have for example an area with +0.2/-0.2 and a zone 100h6 (which means 0/-0.02), there is a way to set on mastercam the nominal quota and make sure that the finishing process is automatically centered in the center of the tolerance zone (in the example would be 99.99)?
I expect that if I have to make a diameter with +0.2/-0.2 and roughness 3.2 the finish is much faster than the same processing (same diameter and same length) but with h6 tolerance and roughness 1.6
hello to all and thanks for the collaboration
good day and good work
roberto
roberto
