Pierandrea58
tolerance of nodellation
o accuracy in ingleseI think that you refer to the "precision" of the calculation in modeling, if so is a rather broad argument as I create can reason in two diferent ways: relative precision and absolute precision.
find this parameter in:
- file
- prepare
- model property
- precision
If you are looking in the forum you will find discussions about the setting of precision, needless to stretch out to repeat already discussed arguments.
exact, modeling toleranceI think that you refer to the "precision" of the calculation in modeling, if so is a rather broad argument as I create can reason in two diferent ways: relative precision and absolute precision.
- file
- prepare
- model property
- precision
should be there from creo parametric 3.0my personal experience on import-export catia-creo is:
- catia v5 solid -> step -> solid import in I create 90-95% of the times.
the few times that it is not solid I correct the surface going in redefinition of the import feature.
- if you have the merged/collaborate license, it helps a lot the import or direct opening in create .catpart file.
(I don't know what version, but it should already be included in the basic package of creo)
