tool framepro bosch rexroth installato su inventor
Daniele_G_11
Hello, everyone.
I installed the rexroth framepro tool with the intent to speed up orders.
when they select a profile from the tool library to import it into the 3d sketch, it does not charge anything by indicating (in the bottom line) only that the import failed.
meanwhile, where the file is saved together, the models of the selected profile are automatically generated but of standard length of supply.
the installation of the tool is automatic and you have no freedom to customize.
the settings of the generated file are like the default (measuring unit or other).
I tried both with sketch 3d created with the tool, and with a created apart without tool.
I tried both while I was logged, and both unlogging, from the vault: Logged seems to be worse because in all generations of the frame, of different dimensions made with a special mask, indicates that the minimum length is too short compared to the minimum 50mm required (see attached image).
Did someone come across this problem?
