creating a warehouse is very simple, you only need a little patience.
Once a tool is created, this is always added to the resource tree and is always the last at the bottom.
place with the right mouse button on the tool select the item "cn Resources" and select send it to warehouse, select whether to create a new warehouse or add the tool to an existing warehouse.
creating a warehouse makes sense, though, if the tools are assigned a tool holder. the tool holder can be designed in the tool box which is the first tab of the tool creation window.
more accurate will be the most accurate tool holder design will be collision control.
attention, only 5 phases of the tool holder are available, in practice the tool holder can be made up of max 5 cylindrical sectors. for other needs you need to draw it in part environment.
Hello and
Let me know!:wink:
