transfer properties from cutting list
  • Thread starter Thread starter Stefano Mombelli
Stefano Mombelli
Good morning, guys.
I would need a advice on how to "transfer" the value of a profile description into the cut-out ("descript sample" in the attached image) to insert it into the generic file properties automatically if possible in the "dim profile" field of the other attached image.
steak
p.
I use the new version of solidworks 2021 which also allows to have in the tables of the properties the possibility to make equations.
the properties that are automatically inserted into the cutting distinct other are just the profile file properties.
instead of completing the property dim profile fill out that description.
be very careful to use global equations and variables in profiles because if you insert two different profiles with variable with the same name will always command the first inserted
common example:
in the profiles binds the radius size to a variable called r; on the angle 50x50x5 the radius (then the variable) is 3, on the angle 80x80x8 the radius (then the variable) is 6; if I insert both the profiles in the same part will command the first variable inserted thus distorting the second profile inserted
common example:
thanks massive,
the information that is inserted in the cutting range I take it directly from the profile properties (I attach an image). I wanted the possibility to "transvade" this info automatically on the property of the part file without doing it by hand with possibility of error.
With regard to the fact that I have multiple profiles in the same structure I am aware of it but it allows me to have later in the separate of the collection information for purchases.
I repeat because perhaps it was not clear:
in the profile file fill out the description entry
I am aware of the fact that I have more profiles in the same structure
I did not write that in a side file you should not use multiple profile types, we would miss anything else; I wrote that if variables or equations are used in profile files you must be very careful because when inserted in the part they overlap with the risk of even heavy errors.
once I modeled a very large frame in which I had various dimensions of heb, which have different internal radius, but for this problem of the variables all the bodies had the same radius; moral of history several dozen reinforcements were to be remade because they did not enter the silhouette and I felt them as a dog from superiors, colleagues and workshop.
in the profile file it is correctly compiled the field "description", the problem is that I do not transfer such info into the properties of the file but keeps it only in the separate cut.
we summarize:
the sldlfp file has nothing to do with this speech.
you want to connect a part file property to a property of its separate cut.
correct?
we summarize:
correct?
exact, cmq the property in the separate cut is correctly inserted by the profile property.
cmq the property in the cutting area is correctly inserted by the profile property.
we do not put forward the profile if not strictly necessary otherwise we risk losing ourselves in chi fa cosa.first question: what if in the part you have more bodies?
the important thing is to have the same profile
It is not true because it is enough that you have 2 equal profiles of different length and you will have 2 folders with 2 properties described in the separate cut.
How do you tell solidworks that he has to fish from a certain folder?
but in the description field I would like to insert the same profile of the tubular e.g. 30x30x2 that if even I had 2 solid bodies of different length the type of tubular is however the same.
It's not the same....
we start from the beginning:
the cut distinction consists of folders that contain all the same bodies for geometry and material.
This means that:
if you have two geometrically equal bodies, but one you do it in s235 and one in s355 you will have two folders
if you have two bodies of the same material, but geometrically different (even for a tenth of millimeter or for a bevel of 0.01x45°) you will have two folders.
so while dealing with the same profile you will have more than one folder.
Now the question is. Since you have to indicate, in some way, solid that has to read the description string, how do you indicate which folder you read?
and as folders may vary during modeling (can increase, decrease, move bodies from one to another) how can solid bind to a specific of these?
*Finally, give me confirmation of this, it is assumed that you should do this at the template level so that you do not have to repeat the procedure, which is, for each part file you create. but in the template you cannot have body folders because you cannot have any body.
* if you want to manage this procedure for each part file, you don't have to do anything but select the description property string and copy it into the file property
