transformation mirror
  • Thread starter Thread starter Tarkus
Tarkus
Hello everyone,:smile:
I'm starting to take some confidence with hypermill, but there are still so many rocks to overcome:
a list of workmanships, pockets, holes, threads... everything ok.
I make a mirroring transformation, it recalculates without problems the milling processes (including a drill made with cylindrical milling),
but punctures and mappings nothing to do: me from these mistakes:
-stop because the initial point is colliding (it does even if I remove the tool control from the initial processing)
- error during calculation of drilling points.
I can't figure it out, can anyone tell me if I'm making some kind of trivial mistakes?
mah, to me holes and threads mirrors them... If you could attach the file maybe I understand more:)
I didn't mirror them if in the same file I made copy mirrored.
on the moment I solved by making a copy of the file and generating the only mirrored paths.
But this morning I relaunched the calculation in the file with mirrored copy and calculated the dx and the copy left without problems.
Maybe I was wrong.
However thanks to the interest :smile:
p.s.
in case you attach a file, you just need to attach the .e3 file, or you need to attach other files, which is, .stl,etc?
