fabry91
Hello, guys.
I have a problem setting up a uniform pressure load on lines.
the loaded structure is a beam188 rectangle, on which a floor is rested. to schematize the weight of the plan I calculated the constant distribution to be applied on the 4 sides [N/m].
the problem is that when I go to apply it (apply-structural-pressure-on lines), and then I run the mesh, the results are all null! then contour plot of movements/tensions etc come of a constant color!
Thanks for the help!
