usare vault
  • Thread starter Thread starter INVENTORMUSTDIE
  • Tags Tags
    vault
INVENTORMUSTDIE
Good morning, I was looking for some tutorials to learn how to use vault or someone who can turn it off:confused:
working on a large set on the server has become improposable, very long waiting times. . .
thanks to the attention
to use is not difficult, looks like outlook.
I just started using it, but we had it installed and configured by an autodesk technician.
According to me it is important how it is set, from there all its operation is born.
Once the environment is created, the whole archive must be moved, and there everything depends on how the existing archive was.
vault does not accept double names, unresolved links and other amenities found in a Windows-based archive.
so first of all the existing archive should be set up and then migrated everything.
for the guide or tutorials within the vault you find them, like those present on inventor
OK thank you, I will try to configure it
- - - updated - - - -Okay thank you, I'll try to configure it.
