veracut 8.1 simplifies the simulation of nc programs
cad3d
Amministratore
Staff member
veracut 8.1 simplifies the simulation of nc programs cgtech has released very8.1, new version of simulation software, verification and optimization for cnc machine tools, which will make machining simulation easier, faster and more efficient.the main innovations regarding the forceTM optimization module, the new additive manufacturing module (am), the new models for reporting, the deployments to sections in machine view, to the x-caliper measuring instrument, to grinding and profiling operations.[TABLE="width: 725"]
<tbody></tbody>[TR][TD][TABLE="width: 466"]
[/TD][/TR]
[/TABLE][/TD][TD]force optimizes nc programs, analyzing strength, particle thickness, progress speed. in this latest version you can view, in real time, charts and diagrams of such parameters at each block. the nc programmer, analyzing the graphs, can associate with peaks of value undesirable cutting conditions such as excessive forces, particle thicknesses or removal rates of non-conform material, tool deflections.[/TD][/TR]
[/TABLE]additive manufacturing (am) simulates both additive processes and removal work, on hybrid cnc machine. the simulation of both operations identifies potential problems due to the integration of the two processes. am carefully monitors the deposited material, detects the collisions between material and machine, finds errors, voids and deposited material incorrectly.
sections in machine view makes it easier and faster to look inside the piece during processing, to control positioning and indentify interference between piece and machine components. with x-caliper multiple labels can be displayed on the piece to control key measures, provide useful information for inspections in the workshop or to be inserted in the log files.
Improved simulation of grinding and revitalizing operations. It is possible to simulate the revitalization, performed by a secondary tool, applied to a grinding wheel to regenerate the cutting surface of the grinding wheel or change its shape. you can simulate the necessary dynamic compensation when the profile tool is used while the grinding wheel removes material.
click qui to know all the news of the new version.
