cad3d has published a new resource:
Verricello - the winches are gear or clutch wheels operated by hand or with motor.
more information about this resource.. .the winches are gear or clutch wheels operated by hand or with electric motor.
are used to lift up to the vertical or horizontal lifting of loads, in the latter case they are called winches.
in figure is represented a classic double gear winch operated manually through the handle m.![]()
from this the bike passes to the first couple of wheels. . .
