width circle
  • Thread starter Thread starter strato72
strato72
Hi, I would like to know if there is the possibility to assign the global width to a circle.
thanks for availability
I apologize for the question, perhaps I was unclear, not the diameter but the overall width that is assigned to a polylinea.
in the circle geometry table I can't manage the overall width, exactly better, I need to thicken the circle line as well as can be done in polylinea.
therefore at the moment your circle is not a polyline; if it is so obviously you can't inspect it if not in print or displaying thick lines that would involve all entities.
you have to turn the circle into polylinea and only then you can manage its thickness.
very kind this is an acceptable solution, only question, can I increase the number of vertices?
in reality rather than making an ellipse with equal axes, changing variables, thickening etc, it is worth using the command ham donut (ring).
asks for external diameter, internal disposition and generates a closed thick pline of circular shape.
