work remotely (vdi) with spacemouse and cadmouse 3dconnexion
  • Thread starter Thread starter supersene
supersene
Good morning to all
are the Italian manager of 3dconnexion
3dconnexion products are able to offer the best interactivity in real time when modeling a 3d object or navigating in 3d environment while the cad renders locally (can also be a browser). if instead the work is done on a remote server and displayed in a client, often you do not have the ideal conditions, due to inevitable complications of the infrastructure, such as the complaints.
this despite the vdi are evolving year after year as well as the powerful software that manage it. In this period, however, smart working must be adapted to use emergency solutions.
then general rules for remoteization with 3dconnexion devices:
• the usb port forwarding must be enabled by the local machine to the remote one. here the list of id devices to recognize them: https://www.3dconnexion.com/index.php?id=200&faq_red=faq/27• it driver 3dconnection non must be executed (arrested or not installed) on computer locale• 3dconnexion driver must run on computer remoto
per hp rgs you should follow this guide: https://www.3dconnexion.it/nc/service/faqs/faq/how-to-configure-remote-usb-in-hp-rgs.htmlwhile microsoft rdp does not support usb passthrough natively. but this is possible with microsoft remotefx. seems that remotefx is now directly integrated with rdp. follow the following instructions:
1. open the start menu on your computer and search for rdp
2. then "remote desktop connection"
3. Click Show Options from the window that appears
4. go to the "local resources" tab
5. select more ... located in the section "local resources and devices"
6. select “other plug and play devices (pnp) support” and “other supported usb remotefx devices” (see below)
rem.webp7. connect spacemouse and try to access the workstation.
with remotefx, the connection should be automatically detected. Otherwise, there may be an option at the top of the remote session to enable the usb passthrough.
for the smartwoking we use "vmware horizon client" and we couldn't configure the devices.
are there guidelines for this application?
Good morning
vmware and citrix are the best brands to manage vdi but it is not trivial to configure them best to use spacemouses. here I bring some forums even if it should be seen case by case:
Good evening,
I wanted to ask if someone, like me, at this time does a day in the company and a day at home...can you find a faster system to use it remotely?
I have a spacemouse pro wireless and on my pcs, both with win10 pro, do not appear the 2 words "plug and play" and "remot fx usb".
I read about forum 3dconnexion.com this discussion link and seems valid software virtualhere , free to share 1 usb (from 2 to pay) any experience about it? What do you say?
Thank you very much to all.
Daniele
Good morning, I also ask you to know if possible to use space mouse from home.
we use anydesk for remote connection and I at home have an imac.
I hope you can give me some info because it would really help you not to be able to use it. . .
I would like to use nache only the space mouse and not the cad mouse I still have...
I wait for hopeful info. . .
Good morning. we say this could be one of the worst configurations to use a spacemouse with a vdi: mac os that from little flexibility + anydesk, an undesigned remoteization software for cad. from a blog: as of now hardware forwarding is not possible, through anydesk. not being able to redirect a usb remotely I fear it is impossible to use a spacemouse (perhaps some additional program, not too cheap, could allow it). I do not exclude that in this period of pandemic and smart working an ad hoc solution is not developing...
Good morning to all
View attachment 579757. connect spacemouse and try to access the workstation.
Hello, luca.
I on vdi vmware horizon use space navigator (wired) without problems but the spacepilot pro after a while is disconnected and fails to receiving the personalizations of control, even importing them.
we installed both locally and on the virtual machine drivers, the same release.
I have turned to the colleague who looks after the link on this page.
available for any clarification.
Mauritius
Hello, luca.
Mauritius
Hello Maurizio,
both spacenavigator and spacepilot pro use the same driver and sensor technology is almost similar. the spacepilot pro has an additional plug-in that allows you to control the screen and surely consumes more current: I don't want there to be any limitation/energy redistribution on the usb port redirection. or maybe it's just bad the spacepilot pro... for these specific cases I recommend to directly feel 3dconnexion assistance: https://3dconnexion.com/it/support/
Hello Maurizio,
thanks to the ready feedback, I verify with colleagues who are dealing with the vdi, the spacepilot pro until I used it locally was fine, the only mistake that gives me is "discontinued device" in the screen "3d connexion properties" that sends me to a page of the site nonexistent 1622556128617.webp
Good to all.
It's definitely a dated discussion, but what I'm about to write is about exactly this topic, with the steps to do today.
at present, 3dxware 10.8.11 drivers, which support these devices
( cadmouse, cadmouse compact, cadmouse compact wireless, cadmouse pro, cadmouse pro wireless, cadmouse pro wireless left, cadmouse wireless ) must be installed both on the vm and on the client system (the drives must always be the same version between host and client ).
done this, there are a set of settings to set on the client and remote operating system (Vm ); In this case I refer to w10 and through the gpedit.msc tool (executable by typing it in the built-in windows search tool ) it is necessary to do the following (I use w10 in English ):
1
computer configuration ->
administrative templates ->
windows components ->
remote desktop services ->
remote desktop connection client -
remotefx usb device redirection.
♪ "allow rdp redirection of other supported remotefx usb devices "
and set usb redirection rights to "administrators and users"
2
remote desktop session host ->
Transport
♪ "allow user to connect remotely by using remote desktop services ".
3
device and resource redirection
disable: "do not allow supported plug and play device redirection".
remote session environment ->
remotefx for windows server 2008
enable: "configure remotefx".
made this restart both systems.
connect the device (by cable; wirelessly does not work ) and launch the 'classic' (integrated w10 and not the remote desktop app with the red icon to interci, as it does not work ).
in the 'local resource' tab in the local device and resource group, clicking on more, the line called 'other supported remotefx usb device' is visible
expand it and check the usb input device (if you have correctly connected the device to the vs system, you will appear the same name of the device ).
all very nice and tested personally, on azure platform.
But there is a problem: At enterprise level, the new remote desktop client (the one with the red icon downloadable even from the ms store ) is taking place.
the problem is that the above, does not seem to give positive results using this application.
I'm investigating to see if it's just a 'mancancy' of the app, drivers or if there are specific and additional settings to implement in the so to run the device also through this app.
If I find anything, I'll update the post.
Good day to all.
