pertengineering
Hello, everyone.
I am doing the first pdm workgroup setup in our office and I find problems.
to begin with I created a folder on our server and I made it rw for everyone, to begin without delay of permits.
I followed all the setup procedure from the disk without problems.The server was created subfolders so the procedure went well.
the problem is I have it in the first login: despite using the pass and user indicated for the egg does not connect.
I tried to see if the pdm workstation service on my pc is started, but I get arrested and if I try to start it, it comes out with " error 1".
I also tried to un-install the program to install it locally, but remember the old path on the server and keep installing it there.
all the procedure I did from my post, should I run it from the server shell?
I ask if someone recognizes these problems and has the solution and if you have a guide on how to completely uninstall the wpdm from linking me.
Thank you very much.
Sergio
Sergio
